Доступен для скачивания здесь. Может, к нам на сайт залить?  Вот основные особенности:
Quote
 - New: Customizable new look
 - New: Layout manager
 - New: Project manager
 - New: Library manager
 - New: Drag and drop files to editor
 - New: Code folding feature
 - New: Autocorrect notification
 - New: Declaration syntax checker
 - New: Advanced bookmark editor
 - New: Macro manager
 - New: New project wizard
 - New: Import Project
 - New: Bug report tool
 - New: Templates for AutoComplete
 - New: Complete Help for IDE + Language and library reference and PIC specifics
 - New: Spell checker
 - Improved: Brackets painter
 - Improved: Code explorer
 - Improved: Docking manager
 - Improved: Messages window with filtering
 - Improved: Grep search feature
 - Improved: Code Assistant, Parameter Assistant
 - Improved: Edit project
 - Compiler
 - Additional chips supported:
 P16F722 P16LF722 P18C242 P18C658
 P16F723 P16LF723 P18C252 P18C801
 P16F724 P16LF724 P18C442 P18C858
 P16F726 P16LF726 P18C452
 P16F727 P16LF727 P18C601
 - New: Command line interface
 - New: Bit, sbit variables support
 - New: Additional set of keywords to fasciliate PIC programming:
 code sbit
 data bit
 sfr rx
 at
 - New: OrgAll pragma added
 - New: PrintOut library added
 - New: Efficient file format for libraries (.MCL)
 - New: definition files with bit definitions included
 - New: mlk files improved (XML file type)
 - New: Compiler front end redesigned for faster compilation
 - New: Remapping local varibales to working register optimization
 - New: Propagation of indirect objects
 - New: MultipAss allocation of functions
 - New: PeepHole optimisation added to Linker
 - New: Compress call optimisation added to Linker
 - Improved: Libraries rewritten to take advantage of new sbit and bit type (smaller and faster code)
 - Improved: pointer to functions added to libraries (SPI, UART) P18 family
 - Improved: Greater flexibility for libraries which use SPI, UART modules (SPI_Glcd, MMC, Ethernet, RS485 etc.) P18 family
 - Improved: Optimizer rewritten
 - Improved: Handling of indirectly called functions
 - Improved: propagation algorithm
 - Improved: Smart interrupt context saving
 - Improved: inline assembler
 - Improved: memory banks handling linker algorithm
 - Improved: Fast and efficient linker algorithm
 - Improved: Fast Hex generator
 - Improved: Fast loading and writing compiled libraries (.MCL)
 - Improved: Messaging system
 - Improved: Output options control
 - Improved: Libraries redesigned and rewritten to meet demands of PIC architecture
 - Improved: Fast and small executable code
 - Improved: Reported bugs fixed
