В мануале сказано следующее:
 Dim Dwd as Dword
 Dim Flt as Float
 Symbol PI = 3.14
 Flt = 10
 Dwd = Flt + PI ' Float calculation will result 13.14,reduced to integer 13
 Print Dec Dwd ' Display the integer result 13
 Stop
 То есть при записи переменной FLOAT в переменную DWORD, в него будет записано целое без долей число.  И еще вот:
 Floating Point Rounding
 Assigning a floating point variable to an integer type will be rounded to the nearest value by default. For
 example:
 FloatVar = 3.9
 DwordVar = FloatVar
 The variable DwordVar will hold the value of 4.
 This behaviour can be altered by issuing the Float_Rounding = Off declare before the conversion takes
 place. For example:
 Declare Float_Rounding = Off ' Disable Floating Point Rounding
 FloatVar = 3.9 ' Load FloatVar with the value of 3.9
 DwordVar = FloatVar ' Truncate 3.9 into FloatVar
 The variable DwordVar will hold the value of 3. i.e truncated
 The Float_Rounding setting will be remembered, as none of the compiler’s floating point library routines
 alter it. However, remember that Floating Point rounding will effect Addition, Subtraction, Division, and
 Multiplication accuracy. It is therefore recommended to re-enable rounding after it has been disabled.
 Declare Float_Rounding = On ' Enable Floating Point Rounding
 Note that the Float_Rounding declare will not effect loading a floating point constant value into an integer.
 This will always be truncated. For example:
 WordVar = 3.9
 The variable WordVar will contain the value 3.
