Написал программу для PIC16F628A,регулятор мощности...
198022alex Дата: Пн, 24.02.2014, 23:35  |        Сообщение # 1
На сайте с 03.02.2014
Написал программу,проверил на железе,работает.Но мне кажется,что написал не правильно.ваши мнения господа.
  PIR1 = %00000000
  PIE1 = %00000000
  VRCON = %00000000
  INTCON = %00000000
  CMCON = %00100101
  TRISA = %11111111
  TRISB = %00000000
  PORTA = %00000000
  PORTB = %00000000
  A VAR BIT
  B VAR WORD
  A=0
  B=9300
  main:
  IF PORTA.0=0 THEN
  B=B+1
  IF B>=9300 THEN
  B=B-1
  ENDIF
  ENDIF
  IF PORTA.3=0 THEN
  B=B-1
  IF B=1100 THEN
  B=B+1
  ENDIF
  ENDIF
  If CMCON.7 = 1 AND A=0 Then
  PAUSEUS B
  PORTB.0=1
  IF B<9300 AND 8300 THEN
  PORTB.1=1
  PORTB.2=0
  PORTB.3=0
  PORTB.4=0
  PORTB.5=0
  PORTB.6=0
  PORTB.7=0
  ENDIF
  IF B<8300 AND B>7100 THEN
  PORTB.1=1
  PORTB.2=1
  PORTB.3=0
  PORTB.4=0
  PORTB.5=0
  PORTB.6=0
  PORTB.7=0
  ENDIF
  IF B<7100 AND B>5900 THEN
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=0
  PORTB.5=0
  PORTB.6=0
  PORTB.7=0
  ENDIF
  IF B<5900 AND B>4700 THEN
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=1
  PORTB.5=0
  PORTB.6=0
  PORTB.7=0
  ENDIF
  IF B<4700 AND B>3500 THEN
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=1
  PORTB.5=1
  PORTB.6=0
  PORTB.7=0
  ENDIF
  IF B<3500 AND B>2300 THEN
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=1
  PORTB.5=1
  PORTB.6=1
  PORTB.7=0
  ENDIF
  IF B<2300 AND B>1100 THEN
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=1
  PORTB.5=1
  PORTB.6=1
  PORTB.7=1
  ENDIF
  PAUSEUS 100
  PORTB.0=0
  A=1
  EndIf
  IF CMCON.7=0 AND A=1 THEN
  PAUSEUS B
  PORTB.0=1
  PORTB.1=1
  PORTB.2=0
  PORTB.3=0
  PORTB.4=0
  PORTB.5=0
  PORTB.6=0
  PORTB.7=0
  ENDIF
  PORTB.1=1
  PORTB.2=1
  PORTB.3=0
  PORTB.4=0
  PORTB.5=0
  PORTB.6=0
  PORTB.7=0
  ENDIF
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=0
  PORTB.5=0
  PORTB.6=0
  PORTB.7=0
  ENDIF
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=1
  PORTB.5=0
  PORTB.6=0
  PORTB.7=0
  ENDIF
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=1
  PORTB.5=1
  PORTB.6=0
  PORTB.7=0
  ENDIF
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=1
  PORTB.5=1
  PORTB.6=1
  PORTB.7=0
  ENDIF
  PORTB.1=1
  PORTB.2=1
  PORTB.3=1
  PORTB.4=1
  PORTB.5=1
  PORTB.6=1
  PORTB.7=1
  ENDIF
  PAUSEUS 100
  PORTB.0=0
  A=0
  ENDIF
  GoTo main:
Прикрепления: Untitled.pbp (2.6 Kb)
ЯНДЕКС Дата: 24.02.2014
ADMIN Дата: Вт, 25.02.2014, 05:22  |        Сообщение # 2
Ну, например, вместо
PORTB.0=1
PORTB.1=1
PORTB.2=0
PORTB.3=0
PORTB.4=0
PORTB.5=0
PORTB.6=0
PORTB.7=0
Можно написать PORTB=%00000011
и так далее...
xvovanx Дата: Вт, 25.02.2014, 13:44  |        Сообщение # 3
Репутация: 65   ±
вот это может давать ошибки
IF B<9300 AND 8300 THEN - во втором условии нет В (8300), Таких две строки
Сообщение отредактировал xvovanx - Вт, 25.02.2014, 13:45
