Форум Picbasic.ru » Программирование на ПК » Программирование на Basic » Proton, PIC Basic Pro, mikroBasic (что лучше)
retas Дата: Пн, 26.12.2011, 21:33  |        Сообщение # 1
Наткнулся на сравнения:
1- Proton
[ + ] Very stable
[ + ] Good and compact generated ASM code
[ + ] All necessary data types (Int, Float, Strings... )
[ + ] a lot of specialized functions (GLCD, LCD, OW, I2C, ...)
[ + ] Good support for USB HID and USB CDC
[ + ] Very nice IDE
[ + ] Proteus interface for simulation
[ + ] MPLab integration (MPSim and debug possible)
[ - ] Flat compiler (no procedure and no functions and all variables are global)
2- PIC Basic Pro (meLabs PBP)
[ + ] Very stable
[ + ] Good generated code (macro based)
[ + ] Only int data types (no float)
[ + ] a lot of specialized functions (OW, I2C, ...)
[ + ] Can be used with Proteus interface for simulation
[ - ] Lack of some data types like Floats
[ - ] No IDE. must use an external IDE (MicroCode Studio)
[ - ] Some recent Specialized functions missing like GLCD support
[ - ] Generated ASM code is fully Macro based. Some what difficult to follow by begginers
3- mikroBasic
[ + ] structured compiler (Procedures and Functions) + modules
[ + ] a lot of specialized functions and libs (GLCD, LCD, OW, I2C, ...)
[ + ] support for USB HID only
[ + ] nice IDE
[ + ] Simulation module
[ + ] proprietary hardware debugger compatible with mikroelektronika dev boards
[ - ] Not stable at all. Every new version introduces a lot of new bugs
[ - ] No Proteus interface for simulation
[ - ] No MPLab integration (MPSim and debug possible)
[ - ] Not compatible with Microchip ICD1/ICD2 (asm code not compatible)
[ - ] the IDE is very problematic (unstable)
[ - ] Generated code is ugly and big (delay routines are repeated systematically)
[ - ] Some times generated code is wrong and does not work
[ - ] USB support limited to HID (no CDC)
Источник
http://webcache.googleusercontent.com/search?....k&gl=lt
ЯНДЕКС Дата: 26.12.2011
ADMIN Дата: Ср, 04.01.2012, 18:32  |        Сообщение # 2
Да, протон рулит. Пришел сам к этому
fredrix Дата: Ср, 22.05.2013, 14:16  |        Сообщение # 3
На сайте с 11.08.2011
Подскажите, как вылечить Протон.
Ставил версии 3.5.0.6; 3.5.2.6; 3.5.2.7 по Win7
Не компилируют. Пишет Error: USB Key not found.
Прилагаемые лекарства применял, тоже самое.....(((((
MiXaS Дата: Чт, 23.05.2013, 16:15  |        Сообщение # 4
Точно не помню, но вроде после того как установил протон, нужно скопировать ехе файл Proton из архива с таблеткой и заменить на тот, который уже стоит.
правой кнопкой мыши на ярлыке Proton, свойства, найти объект, и заменить.
