| DNM |
Дата: Вс, 25.02.2018, 09:52 | Сообщение # 1 |
На сайте с 29.09.2011
Код Device = 18F452 Xtal = 20
Declare Adin_Res 10 Declare Adin_Tad 2_FOSC Declare Adin_Stime 50 ' Declare LCD_Type=0 Declare LCD_DTPin PORTB.4 Declare LCD_ENPin PORTB.3 Declare LCD_RSPin PORTB.2 Declare LCD_Interface 4 Declare LCD_CommandUs 2000 Declare LCD_DataUs 50 Declare LCD_Lines 2
TRISA = %00000111 TRISD = %00000010 ADCON1 = %10000000
Clear ' настроим аппаратный RX/TX модуль Declare Hserial_Baud = 9600 ' Set baud rate to 9600 Declare Hserial_RCSTA = %10010000 ' Enable continuous receive Declare Hserial_TXSTA = %00100000 ' Enable transmit and asynchronous mode Declare Hserial_Clear = On ' Clear the buffer before receiving '
Dim dummy[10] As Byte Dim dat[10] As String * 15 Dim nn As Dword Dim ll As Byte Dim STRING1 As String * 19 'AT - команда посылки данных "AT+CIPSEND=0,N", N - количество посылаемых символов Dim STRING2 As String * 32 'Длина посылаемой строки Symbol CARRY_FLAG = STATUS.0 ' high if microcontroller does not have control over the buffer Symbol ATTACHED_STATE = 6 ' is USB attached
Print At 1,1,"Sim900"
DelayMS 5000 Cls Print At 1,1,"Send" DelayMS 5000
' настроим модуль Sim900 Main1: Clear Cls HSerOut["AT", 13, 10] 'ответ от модуля HSerIn [Wait ("OK"), dummy[0]] Print At 1,1,"AT" Print At 2,1,"OK" DelayMS 1000 Cls HSerOut["AT+CMGF=1", 13, 10] 'включить текстовый режим HSerIn [Wait ("OK"), dummy[0]] Print At 1,1,"AT+CMGF=1" Print At 2,1,"OK" DelayMS 1000 Cls HSerOut["AT+CSCS=",34,"GSM",34, 13, 10] 'установить кодировку текстового режима HSerIn [Wait ("OK"), dummy[0]] Print At 1,1,"AT+CSCS=GSM" Print At 2,1,"OK" DelayMS 1000
Cls HSerOut["AT+COPS?", 13, 10] 'получить информацию об операторе HSerIn [Wait("+COPS: "),Dec dummy[0], Dec dummy[1], dat] Print At 1,1,"AT+COPS?" Print At 2,1,Dec dummy[0], ",",Dec dummy[1],",", Str dat DelayMS 1000 Cls HSerOut["AT+CREG?", 13, 10] 'проверить тип регистрации сети HSerIn [Wait("+CREG: "), Dec dummy[2], Dec dummy[3]] Print At 1,1,"AT+CREG?" Print At 2,1,Dec dummy[2], ",",Dec dummy[3] DelayMS 1000 Cls HSerOut["AT+CSQ", 13, 10] 'проверить уровень сигнала HSerIn [Wait("+CSQ: "),Dec dummy[4], Dec dummy[5]] Print At 1,1,"AT+CSQ" Print At 2,1,Dec dummy[4], ",",Dec dummy[5] DelayMS 1000
LOO: Cls ll=LL+1 HSerOut["AT+CMGS=",34,"+79600000049",34, 13, 10] DelayMS 500 HSerOut[34,"This is the message ",34,Dec ll, $1a]
Print At 1,1,">" DelayMS 5000 Cls GoTo LOO
Config_Start OSC = HS ;HS oscillator OSCS = OFF ;Oscillator system clock switch option is disabled (main oscillator is source) PWRT = On ;PWRT enabled BOR = OFF ;Brown-out Reset disabled BORV = 20 ;VBOR set to 2.0V WDT = OFF ;WDT disabled (control is placed on the SWDTEN bit) WDTPS = 128 ;1:128 CCP2MUX = OFF ;CCP2 input/output is multiplexed with RC1 STVR = OFF ;Stack Full/Underflow will cause RESET LVP = OFF ;Low Voltage ICSP disabled Debug = OFF ;Background Debugger disabled. RB6 and RB7 configured as general purpose I/O pins. CP0 = OFF ;Block 0 (000200-001FFFh) not code protected CP1 = OFF ;Block 1 (002000-003FFFh) not code protected CP2 = OFF ;Block 2 (004000-005FFFh) not code protected CP3 = OFF ;Block 3 (006000-007FFFh) not code protected CPB = OFF ;Boot Block (000000-0001FFh) not code protected CPD = OFF ;Data EEPROM not code protected WRT0 = OFF ;Block 0 (000200-001FFFh) not write protected WRT1 = OFF ;Block 1 (002000-003FFFh) not write protected WRT2 = OFF ;Block 2 (004000-005FFFh) not write protected WRT3 = OFF ;Block 3 (006000-007FFFh) not write protected WRTC = OFF ;Configuration registers (300000-3000FFh) not write protected WRTB = OFF ;Boot Block (000000-0001FFh) not write protected WRTD = OFF ;Data EEPROM not write protected EBTR0 = OFF ;Block 0 (000200-001FFFh) not protected from Table Reads executed in other blocks EBTR1 = OFF ;Block 1 (002000-003FFFh) not protected from Table Reads executed in other blocks EBTR2 = OFF ;Block 2 (004000-005FFFh) not protected from Table Reads executed in other blocks EBTR3 = OFF ;Block 3 (006000-007FFFh) not protected from Table Reads executed in other blocks EBTRB = OFF ;Boot Block (000000-0001FFh) not protected from Table Reads executed in other blocks Config_End
End Просто шлём данные в СМС - на телефон ...
DNM - Вс, 25.02.2018, 09:53
