| Uncle_Dizel |
Дата: Пт, 21.10.2011, 17:19 | Сообщение # 5 |
Пытаюсь разобраться
На сайте с 09.06.2011
DC VAR PortB.6 DTA VAR PortB.5 RST VAR PortB.7 CLK VAR PortB.4 Chr VAR Byte BitMap VAR Word CharCount VAR Byte PosX VAR Byte PosY VAR Byte Column VAR Byte [6] LCDstr VAR Byte [26] LcdData VAR Byte PAUSE 100 GOSUB LCD_INIT PAUSE 100 GOSUB LCD_Clear Start: PosX=0:PosY=0:GOSUB LCD_GotoXY
FOR Chr=0 TO 13 LOOKUP Chr,["NOKIA LCD TEST"],BitMap LCDstr(Chr)=BitMap NEXT Chr GOSUB LCD_StringOut Loop: PAUSE 2000 LOW DC LcdData= %00001101:GOSUB LCD_ByteOut ' Invert PAUSE 2000 LcdData= %00001000:GOSUB LCD_ByteOut ' Blank PAUSE 2000 LcdData= %00001100:GOSUB LCD_ByteOut ' Normal GOTO loop LCD_Init:
LOW RST :pause 20 : HIGH RST : LOW DC ' RESET LCD LcdData= $21: GOSUB LCD_ByteOut ' LCD EXTENDED COMMANDS LcdData= $c8: GOSUB LCD_ByteOut ' SET LCD Vop (CONTRAST) LcdData= $06: GOSUB LCD_ByteOut ' SET TEMP COEFFICENT LcdData= $13: GOSUB LCD_ByteOut ' LCD BIAS MODE LcdData= $20: GOSUB LCD_ByteOut ' LCD STANDARD COMMANDS LcdData= $0c: GOSUB LCD_ByteOut ' LCD IN NORMAL MODE RETURN LCD_ByteOut: SHIFTOUT DTA,CLK,1,[LcdData] RETURN LCD_CharOut: IF lcddata=32 THEN BitMap=216 ' SPACE IF lcddata=42 THEN BitMap=240 ' * IF lcddata=43 THEN BitMap=222 ' + IF lcddata=45 THEN BitMap=228 ' - IF lcddata=46 THEN BitMap=234 ' . IF lcddata=58 THEN BitMap=246 ' : IF LCDData > 47 THEN ' Numbers 0-9 IF lcddata < 59 THEN BitMap=6*(lcddata-48)+156 ELSE ' Capital Letters A-Z BitMap=(LcdData-65) * 6 ENDIF ENDIF FOR Chr=0 TO 5 READ BitMap+Chr,Column(Chr) NEXT Chr HIGH DC SHIFTOUT DTA,CLK,1,[Column(0),Column(1),Column(2),Column(3),Column(4),Column(5)] RETURN LCD_StringOut: FOR CharCount=0 TO 13 LcdData=LCDstr(CharCount) PAUSE 80 GOSUB LCD_CharOut NEXT CharCount RETURN LCD_Clear: PosX=0:PosY=0:GOSUB LCD_GotoXY HIGH DC FOR Chr=1 TO 252 LcdData=0:GOSUB LCD_ByteOut LcdData=0:GOSUB LCD_ByteOut NEXT Chr RETURN LCD_GotoXY: LOW DC LcdData=%01000000 | PosY :GOSUB LCD_ByteOut LcdData=%10000000 | PosX :GOSUB LCD_ByteOut RETURN
'------------------------------------------------- ' Font DATA table '------------------------------------------------- ' DEC Chr HEX Data $7E,$11,$11,$11,$7E,$00 ' 65 A 41 Data $7F,$49,$49,$49,$36,$00 ' 66 B 42 Data $3E,$41,$41,$41,$22,$00 ' 67 C 43 Data $7F,$41,$41,$22,$1C,$00 ' 68 D 44 Data $7F,$49,$49,$49,$41,$00 ' 69 E 45 Data $7F,$09,$09,$09,$01,$00 ' 70 F 46 Data $3E,$41,$49,$49,$7A,$00 ' 71 G 47 Data $7F,$08,$08,$08,$7F,$00 ' 72 H 48 Data $00,$41,$7F,$41,$00,$00 ' 73 I 49 Data $20,$40,$41,$3F,$01,$00 ' 74 J 4A Data $7F,$08,$14,$22,$41,$00 ' 75 K 4B Data $7F,$40,$40,$40,$40,$00 ' 76 L 4C Data $7F,$02,$0C,$02,$7F,$00 ' 77 M 4D Data $7F,$04,$08,$10,$7F,$00 ' 78 N 4E Data $3E,$41,$41,$41,$3E,$00 ' 79 O 4F Data $7F,$09,$09,$09,$06,$00 ' 80 P 50 Data $3E,$41,$51,$21,$5E,$00 ' 81 Q 51 Data $7F,$09,$19,$29,$46,$00 ' 82 R 52 Data $46,$49,$49,$49,$31,$00 ' 83 S 53 Data $01,$01,$7F,$01,$01,$00 ' 84 T 54 Data $3F,$40,$40,$40,$3F,$00 ' 85 U 55 Data $1F,$20,$40,$20,$1F,$00 ' 86 V 56 Data $3F,$40,$38,$40,$3F,$00 ' 87 W 57 Data $63,$14,$08,$14,$63,$00 ' 88 X 58 Data $07,$08,$70,$08,$07,$00 ' 89 Y 59 Data $61,$51,$49,$45,$43,$00 ' 90 Z 5A Data $3E,$51,$49,$45,$3E,$00 ' 48 0 30 Data $00,$42,$7F,$40,$00,$00 ' 49 1 31 Data $42,$61,$51,$49,$46,$00 ' 50 2 32 Data $21,$41,$45,$4B,$31,$00 ' 51 3 33 Data $18,$14,$12,$7F,$10,$00 ' 52 4 34 Data $27,$45,$45,$45,$39,$00 ' 53 5 35 Data $3C,$4A,$49,$49,$30,$00 ' 54 6 36 Data $01,$71,$09,$05,$03,$00 ' 55 7 37 Data $36,$49,$49,$49,$36,$00 ' 56 8 38 Data $06,$49,$49,$49,$3E,$00 ' 57 9 39 Data $00,$00,$00,$00,$00,$00 ' 32 20 Data $08,$08,$3E,$08,$08,$00 ' 43 + 2B Data $08,$08,$08,$08,$08,$00 ' 45 - 2D Data $00,$60,$60,$00,$00,$00 ' 46 . 2E Data $14,$08,$3E,$08,$14,$00 ' 42 * 2A Data $00,$36,$36,$00,$00,$00 ' 58 : 3AДобавлено (21.10.2011, 17.19.38) --------------------------------------------- если я все правильно понел, то это все работает так
FOR Chr=0 TO 13 LOOKUP Chr,["NOKIA LCD TEST"],BitMap Chr(0)....переменная BitMap(N)...LCDstr(0)=BitMap...записываем в массив значение BitMap( получается в кодировке ASCII тоесть ( N=78) LCDstr(Chr)=BitMap NEXT Chr GOSUB LCD_StringOut переходим
LCD_StringOut: FOR CharCount=0 TO 13 LcdData=LCDstr(CharCount) LcdData..присваиваем значение LCDstr(0) тоесть массив (0 адреса тоесть N=78) PAUSE 80 GOSUB LCD_CharOut NEXT CharCount RETURN
LCD_CharOut: IF lcddata=32 THEN BitMap=216 ' SPACE IF lcddata=42 THEN BitMap=240 ' * IF lcddata=43 THEN BitMap=222 ' + IF lcddata=45 THEN BitMap=228 ' - IF lcddata=46 THEN BitMap=234 ' . IF lcddata=58 THEN BitMap=246 ' : IF LCDData > 47 THEN ' Numbers 0-9 IF lcddata < 59 THEN BitMap=6*(lcddata-48)+156 ELSE ' Capital Letters A-Z BitMap=(LcdData-65) * 6 ENDIF ENDIF FOR Chr=0 TO 5 READ BitMap+Chr,Column(Chr) , тоесть у нас получаеться 78+0=78(значит считывает что лежит в 78 ячейки памяти и присваиваем Column(0), это так а как узнать что у нас лежит в 78 ячейки памети? NEXT Chr HIGH DC SHIFTOUT DTA,CLK,1,[Column(0),Column(1),Column(2),Column(3),Column(4),Column(5)] RETURN
| Uncle_Dizel |
Дата: Чт, 01.12.2011, 18:13 | Сообщение # 14 |
Пытаюсь разобраться
Добавлено (01.12.2011, 18.13.43) --------------------------------------------- А проблема в следующем: при преобразовании значения, он преобразует его в "НЕХ", а "мне" нужно в "DEC", а это разные значения и в итоге, будет разный результат... Например: "1" в "DEC" она так и останется - "1" , а вот в "НЕХ" - $31 (пишу по памяти, могу ошибиться...)
если я правильно понел проблему можно просто написать подпрограмму в которой каждое значение символа в "НЕХ" присваивалось соответствующие значение в "DEC" if a=30(HEX) then b = 48(DEC) и так для чисел от (0..9)
...............................................DEC Chr HEX Data $3E,$51,$49,$45,$3E,$00 ' 48 0 30 Data $00,$42,$7F,$40,$00,$00 ' 49 1 31 Data $42,$61,$51,$49,$46,$00 ' 50 2 32 Data $21,$41,$45,$4B,$31,$00 ' 51 3 33 Data $18,$14,$12,$7F,$10,$00 ' 52 4 34 Data $27,$45,$45,$45,$39,$00 ' 53 5 35 Data $3C,$4A,$49,$49,$30,$00 ' 54 6 36 Data $01,$71,$09,$05,$03,$00 ' 55 7 37 Data $36,$49,$49,$49,$36,$00 ' 56 8 38 Data $06,$49,$49,$49,$3E,$00 ' 57 9 39
Uncle_Dizel - Чт, 01.12.2011, 18:14
